Frank D
#1 Posted : Saturday, May 29, 2010 6:20:58 AM(UTC)
Frank D
Top rack dishes are not getting clean in my old Kitchen Aid. I figure that the food chopper might be clogged but darn if I can figure out how to get to it. I can get the lower impeller off... that was simple, it just lifts right off. However, the rest of the lower assembly looks like trouble. I'm afraid if I get it apart, I won't get it back together. Does anyone have step-by-step instructions of how to take apart the lower unit enough to get at the food chopper? It is a model KUDH230BWH0. Thanks!!!
#2 Posted : Saturday, May 29, 2010 1:08:31 PM(UTC)
mandmtech
#3 Posted : Sunday, June 13, 2010 7:03:19 AM(UTC)
mandmtech
Hello Frank,
Is there a quick step by step guide to get to the food chopper on my Kitchenaid Dishwaher Model KUDI01DLBT3? I am new to the site and my local appliance repair guy found tons of food and other FMM (foriegn material and matter). I ran into the same issue you did....can you send me the step by step guide to get to the food chopper blade and screen???
Bests,
MandMTech
carlpdavis
#4 Posted : Sunday, July 11, 2010 6:11:38 PM(UTC)
carlpdavis
After you get the main strainer off, down in a well there is a 2-piece cover over the food chopper. It is held in place with two #15 Torx screws. It lifts straight up. It is tight and will need some nudging. This exposes the food chopper, which is driven off the pump shaft by a 4-prong coupling.
