chris cooper
#1 Posted : Saturday, January 17, 2009 7:02:31 AM(UTC)
chris cooper
Does anyone know how to replace the door handle on a Samsung microwave? It is a stainless steel post joined by two plastic caps at each end. The caps seem to be held from inside the door and I can't get inside the doot to replace the plastic caps.
sarabrinson
#2 Posted : Saturday, June 12, 2010 6:41:26 AM(UTC)
sarabrinson
We have the same problem. Did you ever find out how to fix it? Thanks. :confused:
chris cooper
#3 Posted : Saturday, June 12, 2010 8:36:57 AM(UTC)
chris cooper
Look inside the door and there is a plastic insert around the glass. Take a flathead screwdriver and remove the entire rectangular liner. You can replace the caps and put the ring back on.
microwave door handle replacement (Microwave Repair)
by jjtuttle@flash.net 1/17/2011 8:58:28 AM(UTC)
Microwave door handle replacement (Microwave Repair)
by Atul 12/23/2010 6:43:28 PM(UTC)
GE Microwave door handle replacement (Microwave Repair)
by neel72 11/6/2008 3:48:25 PM(UTC)
