neel72
#1 Posted : Thursday, November 6, 2008 3:48:25 PM(UTC)
neel72
I received the door handle from this site, I was able to remove the Plastic cover 1804 from the door, then I was able to remove the top screw for the door handle. To reach to the bottom screw I need to remove the metal frame which hold the glass.
I cannot remove this , need help on how to remove this and to reach to the bottom screw.
Looking forward for your help.
Neel:rolleyes:
abadfish66
#2 Posted : Thursday, November 6, 2008 3:57:44 PM(UTC)
abadfish66
You should notice 3 plastic tabs on top an3 3 on bottom, and 2 on each side. You will need to carefully work the metal out of those tabs until it seperates. It is a whole lot easier if you remove the door from the oven first. Take off the grille above the door, it is held in by 2 screws up top, then just lift the door off the hinge.
neel72
#3 Posted : Thursday, November 6, 2008 4:13:30 PM(UTC)
neel72
I am able to get the door out of the Microwave. but not able to get the tabs disengage the metal frame.Is there easy way get that open.
Thanks for your prompt response.
abadfish66
#4 Posted : Thursday, November 6, 2008 4:27:28 PM(UTC)
abadfish66
Your gonna have to just work it out. It will come, just takes some finesse, bend the tabs a bit and work it out, one at a time.
