2 Pages<12
Truspark
#11 Posted : Thursday, June 10, 2010 5:12:01 AM(UTC)
Truspark
thanks I got the piece yesterday and it looks like the right one. Now all I need to do is figure out how to take the door off, I assume I take unscrew the door from the hinge (a single screw seems to hold it in) and not the hinge from the entire cabinet. I'm thinking once that screw is off the door should just lift off? and I can pop out the bearing and replace it with the new one?
#12 Posted : Friday, June 11, 2010 2:51:23 AM(UTC)
Not sure which part you received but usually you have to remove the hinge to get at the door (I think).
Note: That I am off to the lake for a few days so will not be available.
Hopefully you will get it fixed without any problems.
2 Pages<12
