Gerhard
#1 Posted : Thursday, June 3, 2010 9:59:14 AM(UTC)
Gerhard
The water dispenser stopped working. Before it always made a click noise when i press the button for water and another click when i release the button. Now it no longer make the click sound and no water comes out. It seems a valve no longer opens or a slenoid is not kicking in. I have replaces the water fitter. Where do I start:confused:
#2 Posted : Thursday, June 3, 2010 2:42:24 PM(UTC)
The problem can be a bad dispenser control board or a bad solenoid. Perform the troubleshooting as instructed in the Service manual and post the results.
Here are the breakdown diagrams and Fountain replacement parts for MAYTAG MZD2669KEB Ref - SXS/I&W | AppliancePartsPros.com
Gerhard
#3 Posted : Wednesday, June 9, 2010 4:00:04 PM(UTC)
Gerhard
I received the part but how do I remove the in and oulet lines from the unit. It seems they just slide in, how do I get them out without cutting them?
#4 Posted : Wednesday, June 9, 2010 7:44:44 PM(UTC)
To disconnect the tube, push in the white or blue collar on the quick connector and pull the tube out.
Gerhard
#5 Posted : Thursday, June 10, 2010 4:21:22 PM(UTC)
Gerhard
The refrigirator is up and pumping water again - thanks for your help
Gerhard
#6 Posted : Thursday, June 10, 2010 4:23:10 PM(UTC)
Gerhard
the refrigirator is up and pumping water again - thanks for all the help
#7 Posted : Thursday, June 10, 2010 5:42:38 PM(UTC)
You are welcome. I'm glad you were able to fix it.
