The water dispenser stopped working. Before it always made a click noise when i press the button for water and another click when i release the button. Now it no longer make the click sound and no water comes out. It seems a valve no longer opens or a slenoid is not kicking in. I have replaces the water fitter. Where do I start:confused:
I received the part but how do I remove the in and oulet lines from the unit. It seems they just slide in, how do I get them out without cutting them?
To disconnect the tube, push in the white or blue collar on the quick connector and pull the tube out.
Originally Posted by: Gene  To disconnect the tube, push in the white or blue collar on the quick connector and pull the tube out.
Gene. The refrigirator is up and pumping water again - thanks for your help
the refrigirator is up and pumping water again - thanks for all the help
You are welcome. I'm glad you were able to fix it.
