squigoth
#1 Posted : Monday, May 26, 2008 2:02:54 PM(UTC)
squigoth
I have a 9 year old Whirlpool refrigerator of the above model number that now drips water into the frig area from the diffuser area. The freezer is fine and the frig is cold, as a matter of fact I have ice in the bottom of the frig. This unit is in my garage which can get quit hot during the daytime (95+). I've had this problum for about two weeks now.
I need some help finding the problum.
squigoth
#2 Posted : Tuesday, May 27, 2008 4:06:58 PM(UTC)
squigoth
Update: I have the frig set to 2 and there is still some ice in the frig part of the box up by the diffuser. When I try and adjust the freezer setting the dial is frozen in place a bit and it feels like I have to "break" some ice to free it before it turns.
#3 Posted : Wednesday, May 28, 2008 1:35:58 PM(UTC)
Usually it happens if the door was open too frequently or it was ajar. Remove all ice from the diffuser and check the door seals.
P.S. The model number you posted does not come up.
squigoth
#4 Posted : Wednesday, May 28, 2008 6:28:31 PM(UTC)
squigoth
Thank you. I'll check the door seals and the diffuser for ice.
It's ET18NKXFW03... I left out the T...
#5 Posted : Thursday, May 29, 2008 1:12:35 PM(UTC)
Because of the improper model number I thought it is a SxS fridge. Now I realized this is a top-mount refrigerator and it makes some difference in the diagnosis of such problem.
Most likely the cause of it is a clogged and/or frozen drain.
Remove the freezer floor and the rear panel in the freezer. Check the drain (under the evaporator coil). You can use a hair dryer to defrost it and then run a few cups of hot water through the drain.
Here are the break down diagrams for the Whirlpool refrigerator Model ET18NKXFW03
