aorose
#1 Posted : Tuesday, May 27, 2008 11:38:52 AM(UTC)
aorose
The washer just keeps filling up and won't stop. I see on several sites where they have a water valve listed but this looks like the part where the water hooks to the machine.
What should I check/How do I fix this?
Thank you for all your help.
#2 Posted : Wednesday, May 28, 2008 3:16:28 AM(UTC)
If you have to shut the water off to the washer to stop the flood, you have a bad water solenoid in the washer.
okbobcats
#3 Posted : Wednesday, May 28, 2008 3:33:52 AM(UTC)
okbobcats
you might want to check your drain hose. to make sure water not running out of it during water fill. u never stated if it was over filling.
