Kimla
#1 Posted : 18 years ago
Kimla
This refridgerator was given to me and I hooked up water & it works out of water dispeser but icemaker won't. I can pour water in ice maker and it will freeze and drop. It's not getting water to icemaker.
#2 Posted : 18 years ago
Hi Kimla
Most likely the problem is a bad solenoid on the dual water valve (#1 on the ice maker break down diagram).
- The part number for the new dual water valve AP3103466
- Here are the break down diagrams for the Whirlpool refrigerator Model ED25SM1LWR0
Good luck.
Kimla
#3 Posted : 18 years ago
Kimla
I tried last night & switched the water line to the ice maker, but you have to push in the water to fill up ice maker & if you don't stop it will over flow. Do you still think its the solenoid?
Kimla
#4 Posted : 18 years ago
How did you switch lines? They have a different size: the tube for the ice maker 1/4" and the tube for the drinking water 5/16".
Kimla
#5 Posted : 18 years ago
Kimla
My husband is very talented,Ha!Ha! I don't know, I am going to try a new solenoid.Thank you very much ,I'll let you know when it works.
Kimla
Refridgerator/Freezer not cooling enough (Refrigerator & Freezer Repair)
by blbrchnk 8 years ago
Refridgerator/freezer blowing only slightly cool air (Refrigerator & Freezer Repair)
by dylan 13 years ago
Maytag refridgerator/freezer (Refrigerator & Freezer Repair)
by dav4 14 years ago
Refridgerator/Freezer, cold on the bottom NOT on the top (Refrigerator & Freezer Repair)
by mmkrussell 16 years ago
Refridgerator/Freezer (Refrigerator & Freezer Repair)
by john g1 16 years ago
Refridgerator/freezer not getting cold (Refrigerator & Freezer Repair)
by trying times 17 years ago
Refridgerator/Freezer won't cool (Refrigerator & Freezer Repair)
by klamath 17 years ago
