RichardMoody
#1 Posted : Friday, June 4, 2010 1:28:33 PM(UTC)
RichardMoody
Ice has formed behind the wall in the freezer preventing air flow so the refrigerator is warm... Do I need a Defroster Relay or something like that is not working?
#2 Posted: : Friday, June 4, 2010 3:38:15 PM(UTC)
Here are your parts includes a wiring diagram
Replacement parts for MSD2756DE models | AppliancePartsPros.com
Here is a manual
http://www.servicematters.com/maytag_library/docs/16010154.pdf
See Page2-15 on how to force a defrost cycle.
You do not need a watt meter.
First remove the evaporator cover in the freezer so you can see the coils.
Not do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle.
The the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the adaptive defrost board needs replacing.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost board's contacts are toast and it needs replacing
RichardMoody
#3 Posted : Monday, June 7, 2010 2:42:39 PM(UTC)
RichardMoody
Thanks for the helpful post... GREAT. But I went and tried to find the adaptive defrost board so I could test that... My daughter has this same Refrigerator and that is the same part that went out... She brought me her old one so I know what I am looking for but where is it so I can test it like the manual you sent tells me to do? I removed all the easy covers and can't see it... Is it behind the Ice maker? I hope not!!
#4 Posted : Monday, June 7, 2010 3:18:29 PM(UTC)
In the parts breakdown take a look at Section 2 Item 13
RichardMoody
#5 Posted : Monday, June 7, 2010 7:31:50 PM(UTC)
RichardMoody
Thank you... I looked at that and now I see it... I guess I was just blind... Thanks for all your help
Refrigerator not defrosting properly (Refrigerator & Freezer Repair)
by Jessicam 6/7/2017 8:11:30 PM(UTC)
Refrigerator not defrosting (Refrigerator & Freezer Repair)
by wrightwaw 2/2/2011 10:10:04 AM(UTC)
Frigidaire Refrigerator not defrosting (Refrigerator & Freezer Repair)
by pantera65 9/30/2010 8:39:21 AM(UTC)
Admiral Refrigerator Not Defrosting? (Fridge Slowly Gets Warm) (Refrigerator & Freezer Repair)
by rvegola 7/15/2009 4:06:55 PM(UTC)
refrigerator not defrosting (Refrigerator & Freezer Repair)
by Will2cool 6/2/2008 1:11:07 PM(UTC)
