Would appreciate any help you can give me. The dual burner on the right front of the cooktop has only the small burner working. How can I determine what part to order or what part should I order? Thanks for your help.
Bob Morris
Hi Bob, The problem can be a bad heating element or a bad switch for this burner. You have to check both parts for continuity in order to minimize the cost of repair. The mini-manual should be inside the control panel. - The dual infinite switch Part number: AP2622889
Gene,
Thank you very much. I'll try the continuity check.
Bob
You are welcome Bob. Keep us posted.
