Ron,
Sounds like the problem is a bad control board. "Jenn-Air Gas Range Electronic Touch Control 800" is not a valid model number. Look for the name plate on the door frame, ion the frame behind the bottom drawer or on the back of the control panel.
Originally Posted by: coljpt  Dear Gene: Thank you so much for your post on the 5ab maytag fix.. I was setting the time when it locked in the Sabath mode.:( I tried to shut stove down at breaker switch ,no luck then I was in the process of fabricating a story to tell my wife ,:confused: when I found your post.:D Ahh sweet peace... No lying ... No nagging...:rolleyes: Thank you again.. Coljpt :cool: Think LIke A MAN, and I did, and this post is like reading my mind. Maytag 5ab :confused: :( yes breaker switch :cool: :mad: yes fabricating a story :o yes found this post :cool: Yes Pushing the clock button 3 seconds fixed the problem ;) Yes Sweet peace, no lying, no nagging :D Yes Dollar signs of repair man gone :D Yes Thank God for this site :) Yes
Thank You so much!! I tried everything i could think of!!You are a lifesaver!!
Mine has the same exact problem, for the same reason. Did anyone contact you, beside the person who said Jenn Aire? You clearly said it was a Maytag (like mine)...
Hello, and THANK you for the simple fix...for some reason nothing came up initially on the first post, and didn't until after I asked my question. Duh.
Yes, it worked, and I am cookin' again.
Eres un genio, desde mexico te doy las gracias!!!!!!!!!!!!!!!
You are welcome. Eres bienvenido.
Holding down the clock for 3 seconds worked for me too. Originally Posted by: sewsew  I have gotten the strangest error code 5Ab on my Maytag Range display. My husband reset the time last Sunday (the 4th) for DLS(Daylight Savings Time) and last night this message code appeared. The top burners will light but the oven WILL NOT WORK. Any help or advice would be greatly appreciated! Thanks :)
Gene, you saved my bacon also. I went shopping today and was going to buy a new range tomorrow. My range got about 2' of water during Hurricane Ike. I had to replace the ignitor a couple of months ago and really didn't want to spend any more money on this range. I thought my error code said 5 A6 or 5 Ab. Thanks!! Now if you can tell me how to fix my Frigidaire side by side that also got flooded. I actually feel pretty lucky to have had this work for 3 1/2 years after the flood.
Originally Posted by: GalvestonBay  ...Now if you can tell me how to fix my Frigidaire side by side that also got flooded... You are welcome. I'm glad that the problem with your range was that simple and you were able to fix it. We'll be more than glad to help you with your fridge. Just open a new thread in the refrigerator part of the forum with detailed description on the problem. Do not forget to post the complete model number of the fridge. Gene.
