3 Pages123>
acillatem
#1 Posted : Thursday, July 19, 2007 8:07:28 PM(UTC)
acillatem
Hi, Hope I can get some suggestions regarding our range. A few days ago, the oven decided it would not heat up, just out of the blue. It worked fine the night before. The display shows that it is on, the temp, etc..........just no heat. The fan is coming on, but all the heating elements are cold.......no heat at all. It was suggested by a couple people that it may be a heating element, or most likely the ERC board. Correct me If I'm wrong, but all 3 heating elements in the oven wouldn't go out at the same time, correct? If one was out the other two would still work, I'm assuming. Based on that, I took a chance and ordered the new ERC board from here.........it arrived today, I put it in, and no change at all. Now I've spent $165, and still have an oven that doesn't heat up, and a non returnable part. The only good thing that came out of that is the buttons are much easier to push than the old board. They were never easy, and we asked the service guy about it when he was fixing something else, and he said it was normal because of the way the board attches to the control panel, and we believed him. Anyway, at least there is a positive to the new ERC board, but the oven still doesn't heat up.Any ideas??? Could it be the oven temperature sensor? I'm running out of things it could be, I think. Any help greatly appreciated. Thanks in advance!
Admin / APP Team
#2 Posted : Thursday, July 19, 2007 11:31:01 PM(UTC)
Admin / APP Team
Rank: Administration
acillatem,
What about the surface elements? Do they work? If not, check the circuit breaker.
Assuming the circuit breakers are fine and your range is getting 220 volts (and not just 110 volts)... - I checked your model and don't see a fuse, however I do recall more than one case where KitchenAid forgot to include the fuse on the diagrams...
Try this: disconnect the power to the range first. Then, remove the back panel of the range. You should see the ends of all three oven elements. First, see if there is anything that looks like a fuse on the back wall of the range (small plastic component with two wires connected to it). If you don't see anything like that, you can trace the common wire and see where it leads to (there is a common wire that all three elements share). If there is no fuse (or thermostat), chances are it leads to the common relay on the board. This is where I would typically recommend replacing the board, but you've already done that. Let me know what you find. If you do see a fuse, get the 7 digit number off of it and post it here.
acillatem
#3 Posted : Friday, July 20, 2007 5:41:54 AM(UTC)
acillatem
Originally Posted by: Admin / APP Team Go to Quoted Post
acillatem,
Yes, everything else works just fine.........it's just the bottom oven that won't heat up on bake or broil. I'll check for fuse after work, and let you know......thanks!
acillatem
#4 Posted : Friday, July 20, 2007 8:27:15 PM(UTC)
acillatem
acillatem,
I have looked very thoroughly, and there is no fuse. Up in the top control panel all around the ERC board, and in the back after removing the back cover. I even followed the thick red wire down to the pigtail, and no fuse of any kind. I'm not kidding, it's not there, unless they hid it under the cooktop on mine, and I doubt that. I went and bought an Ohm Meter today, and checked all 3 elements, and all 3 registered zero when tested, which is what I should get if working correctly, right? And I checked the oven temperature sensor, and it measured 1000 ohms resistance, which I've been told is what it should be......hopefully that was accurate information. I did find the common wire that all 3 elements share, and it is a brown wire that ends up going to a sort of tan wire that ends up at some terminal on the ERC board, and the plastic over the connector has a kind of "burned" look to it, which seems odd to me. From what I can see, it still appears solid, so I'm assuming there is still a good connection, but this could be the problem, so I have a couple pictures, to see if anyone agrees, or has an idea what is going on with this. It is linked to the 3 elements, so maybe this is the culprit. Here are the 2 pictures:
http://i80.photobucket.c...alliholic06/DSCF1875.jpg
http://i80.photobucket.c...alliholic06/DSCF1874.jpg
Again, any advice greatly appreciated,and thanks in advance! I almost called the local repair place today after the new board didn't solve the problem,but I have this feeling it's something simple now. Sure hope so anyway. I don't give up easily lol.
Admin / APP Team
#5 Posted : Friday, July 20, 2007 10:39:12 PM(UTC)
Admin / APP Team
Looks good (read "bad") to me. Since you have a meter, go ahead and check that wire for continuity. Unplug it from the board, put one meter lead on each end and see if there is a break, probably at the terminal. But either way, that terminal looks pretty burnt up. I would recommend changing it. Radioshack should have one.
Let me know how it goes.
acillatem
#6 Posted : Friday, July 20, 2007 11:12:15 PM(UTC)
acillatem
So(since this is foreign to me), I pull that wire in the picture off, and then do I simply find the next break in that same wire, and then test it from those 2 ends??? Do I leave the meter on OHMs? I consider myself pretty handy, but electrical stuff is uncharted territory to me, for the most part, that's why I ask. What do you think caused that terminal to do that, and If I go to Radioshack, is there any special thing I need to ask for, or simply clip that terminal off, and say "i need one of these"? And thank you very much!
Admin / APP Team
#7 Posted : Saturday, July 21, 2007 10:36:10 AM(UTC)
Admin / APP Team
acillatem,
After checking your photos again, I think you don't have to worry about testing the wire for continuity. Replace the terminal and that should do it. If you'd like to know how to test for continuity anyway, let me know.
What you need is a 1/4 inch female insulated terminal. Cut the old one off, leaving about half an inch of the wire on it. Take it to Radioshack. If you've never replaced a terminal before, the counter people should be able to show you how, and probably try to sell you wire strippers as well :).
Keep us updated please. I'm curious to know what happens.
acillatem
#8 Posted : Saturday, July 21, 2007 12:01:46 PM(UTC)
acillatem
acillatem,
Thanks again..........just got back from Radio Shack.....had to find it myself, the guy looked puzzled lol. Couldn't find a right angle one, but oh well, no big deal, straight will work. I've got crimpers and whatnot......I've done this kind of thing, so hopefully this is it. I would find it hard to believe that I would have bought a brand new board that would have a bad relay......anything is possible, but that would be pretty rare, I'm assuming.
Admin / APP Team
#9 Posted : Saturday, July 21, 2007 2:03:56 PM(UTC)
Admin / APP Team
I agree, although possible, it's pretty rare for a new board to be defective. Of course if it is, you've got the warranty, and we'll take care of it right away.
Let me know what happens.
acillatem
#10 Posted : Saturday, July 21, 2007 2:42:02 PM(UTC)
acillatem
O.k. the idiot sold me the wrong connectors, so I had to go back. I'll be doing all the testing and whatnot soon. The guy on the phone said electrical parts are not returnable, but you're saying it is under warranty?
3 Pages123>
