emidgette
#1 Posted : Tuesday, June 1, 2010 4:58:30 PM(UTC)
emidgette
I started the self-clean cycle but stopped it before it was completed. I tried it again the next day and got an F3 code and the pre-heat light was blinking. I turned off the circuit breaker and turned it back on. The next day I tried to use the oven (to cook, not to clean). It seemed to operate ok for a little while, but then it started beeping and I got an F2 code. The oven never got hot. Any suggestions?
#2 Posted : Wednesday, June 2, 2010 3:55:06 AM(UTC)
A Model Number may help others help you.
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 6/1/2010 4:56:50 PM(UTC)
