sstarrat
#1 Posted : Friday, May 23, 2008 6:52:42 AM(UTC)
sstarrat
My older model gas dryer will not heat. It has an electric igniter. Everything else is working fine, except the heating element. How can I fix this, and will it be very exspensive? Thanks
SublimeMasterJW
#2 Posted : Friday, May 23, 2008 3:41:45 PM(UTC)
SublimeMasterJW
Flame sensor100_1895comp.jpgThis guy over the years will develop an open circuit and not allow for the igniter to come on.
SublimeMasterJW attached the following image(s):
SublimeMasterJW
#3 Posted : Friday, May 23, 2008 3:52:57 PM(UTC)
SublimeMasterJW
The fuse mounts on that burner chamber where the flames enters.
If the ignitor is open it is bad. If the dryer works just a little but quits heating then replace these:100_1974comp.jpg
