when in the spin cycle it makes a loud noise sounds like a bearing going out could this by the problem. also have been getting grease on clothes.
Put the washer in spin and hold the spin basket from turning. Does the noise go away??
i tried running the machine with out any cloths in it and it seem to run fine and i held the basket and it seemed to go away. do you think the machine could of been overloaded? thank you
If no oil coming out of the tub seal, you have a bad transmission, bad internal bearings.
