rzbackfan
#1 Posted : Tuesday, May 20, 2008 3:17:36 PM(UTC)
rzbackfan
when in the spin cycle it makes a loud noise sounds like a bearing going out could this by the problem. also have been getting grease on clothes.
#2 Posted : Tuesday, May 20, 2008 3:56:35 PM(UTC)
Put the washer in spin and hold the spin basket from turning. Does the noise go away??
rzbackfan
#3 Posted : Wednesday, May 21, 2008 3:55:33 PM(UTC)
rzbackfan
i tried running the machine with out any cloths in it and it seem to run fine and i held the basket and it seemed to go away. do you think the machine could of been overloaded? thank you
#4 Posted : Thursday, May 22, 2008 12:32:58 AM(UTC)
If no oil coming out of the tub seal, you have a bad transmission, bad internal bearings.
loud noise when in spin cycle (Washer Repair)
by rzbackfan 5/20/2008 3:14:48 PM(UTC)
