Jim W.
#1 Posted : Wednesday, May 26, 2010 3:46:03 PM(UTC)
Jim W.
This is 2nd posting as I didn't get answer on 1st. Refrigerator cools and freezes ok, but the motor intermittently runs & shuts off, runs & shuts off, runs & shuts off, sometimes for mere seconds, sometimes longer. The fan has been replaced with no results except that my wallet is lighter by $180.
Can you advise what the problem is and what part(s) I need to fix it?
Jim W.
#2 Posted : Wednesday, May 26, 2010 3:53:58 PM(UTC)
Jim W.
Please answer my question!
#3 Posted : Wednesday, May 26, 2010 6:34:39 PM(UTC)
Which fan?
What motor?
Jim W.
#4 Posted : Thursday, May 27, 2010 11:10:28 AM(UTC)
Jim W.
Hi Denman:
By Fan, I mean the little motor & Fan in the Freezing compartment. By Motor, I should have said Compressor runs & shuts off.I'm sorry, but I don't understand your reply. What Filter under Ice Maker? (Didn't know there was one). My freezer is cold and so is fresh food side. Please reply. Thank you.
#5 Posted : Thursday, May 27, 2010 3:21:17 PM(UTC)
Originally Posted by: Jim W. Go to Quoted Post
...runs & shuts off, runs & shuts off, runs & shuts off, sometimes for mere seconds, sometimes longer...
If the compressor works this way, it'll never create and maintain proper temperature in both compartments.
You said:
Quote:
...sometimes longer...
How much longer?
Try to be as much specific on the problem as possible. Do not forget: only you are our eyes and ears. All our advices are based on the information posted by you.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RT21LMXJW00 | AppliancePartsPros.com
Jim W.
#6 Posted : Thursday, May 27, 2010 4:27:12 PM(UTC)
Jim W.
Gene, I'll have to time it. Fridge is located in 2nd home, so it will be some time before we go there. I will time it and also check temperature in both compartments. Thank you
#7 Posted : Friday, May 28, 2010 2:22:52 AM(UTC)
Here is a wiring diagram for a W01.
Could not find a diagram for a W00 but the above should be close to yours.
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%202201079.pdf
[COLOR="Blue"]I'm sorry, but I don't understand your reply. What Filter under Ice Maker? (Didn't know there was one).[/COLOR]
I did not say anything about a Filter, so you have lost me.
Guest (5)
