This is 2nd posting as I didn't get answer on 1st. Refrigerator cools and freezes ok, but the motor intermittently runs & shuts off, runs & shuts off, runs & shuts off, sometimes for mere seconds, sometimes longer. The fan has been replaced with no results except that my wallet is lighter by $180.
Can you advise what the problem is and what part(s) I need to fix it?
Please answer my question!
THIS FORUM IS DEAD!!!!!!! |
Hi Denman: By Fan, I mean the little motor & Fan in the Freezing compartment. By Motor, I should have said Compressor runs & shuts off.I'm sorry, but I don't understand your reply. What Filter under Ice Maker? (Didn't know there was one). My freezer is cold and so is fresh food side. Please reply. Thank you.
Originally Posted by: Jim W. ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...runs & shuts off, runs & shuts off, runs & shuts off, sometimes for mere seconds, sometimes longer... If the compressor works this way, it'll never create and maintain proper temperature in both compartments. You said: Quote:...sometimes longer... How much longer? Try to be as much specific on the problem as possible. Do not forget: only you are our eyes and ears. All our advices are based on the information posted by you. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RT21LMXJW00 | AppliancePartsPros.comGene.
Gene, I'll have to time it. Fridge is located in 2nd home, so it will be some time before we go there. I will time it and also check temperature in both compartments. Thank you
