patsz26
#1 Posted : Wednesday, May 26, 2010 11:36:28 AM(UTC)
patsz26
Heavy Duty Super Capacity 2 Speed Motor with 3 speed Como's
Kenmore Top Load Serial #CL2908176 Type 111
The washer only fills with water. That is the function it will perform! Please help! I've got the back off and the lid switch does work!
HELP!!!!
#2 Posted : Wednesday, May 26, 2010 8:07:02 PM(UTC)
How did you check the lid switch?
If you are sure the lid switch is fine, then remove the wire plug from the water level switch, bypass the V & T wires and see if the washer will start. If it did, replace the water level switch.
- The water level switch Part number: AP3020315
patsz26
#3 Posted : Wednesday, June 2, 2010 3:06:48 PM(UTC)
patsz26
How am I supposed to check the lid switch? It clicks and seems to work fine.
I cannot lift the lid up to get to the switch. The washer only allows a rear entry. So, I've taken the back off. Is there another way to check it?
#4 Posted : Wednesday, June 2, 2010 8:13:26 PM(UTC)
The lid switch has to be checked for continuity. If you would like to fix it yourself and save some $$$, then you have to gain enough access to the washer.
