kabowabo1
#1 Posted : Monday, May 24, 2010 4:00:30 AM(UTC)
kabowabo1
The fan in top freezer is making a high pitched noise. It runs but every 30 seconds or so, it like stops makes a high pitch noise then continues to run. Maybe I should just replace it.
#2 Posted : Wednesday, May 26, 2010 5:34:09 AM(UTC)
Replacement parts for WHIRLPOOL ET20HKXMWR0 | AppliancePartsPros.com
Yes I would replace it before it stops completely and you loose some of the food, Item 6 in Section 2.
Also the unit will run more efficiently if the fan is circulating the air properly.
