rzbackfan
#1 Posted : Tuesday, May 20, 2008 3:14:48 PM(UTC)
rzbackfan
when the washer is in the spin cycle it makes a loud noise. just wondering if it could be the bearing going out. have also had a problem getting grease on clothes. please help
#2 Posted : Wednesday, May 21, 2008 1:06:16 PM(UTC)
Remove the front panel and check for water leak from the central seal. Also check the belt.
#3 Posted : Friday, May 23, 2008 2:24:52 AM(UTC)
Also, put the washer in spin and hold the spin basket from turning, if you still get a bearing noise, you have a bad transmission.
loud noise when in spin cycle (Washer Repair)
by rzbackfan 5/20/2008 3:17:36 PM(UTC)
