I removed my gas oven when doing some remodeling an unfortunatly bent the rigid aluminum tubing that connect from the flex gas line to the back of the over. I think it is actualy part number AP2026980 . It have flare fittings on both ends but on my oven it is bend like a horseshoe and the in the catalog it is straight. I know these are hard to bend without the proper tool. Do you think I have the right part?
The new tube comes straight and has to be bend at the installation time. You have to use a special bending tools to do it right. The part number you posted is correct. The bending tools: - The set of bending springs Part number: AP3550535
