dherman201
#1 Posted : Friday, May 21, 2010 8:39:14 AM(UTC)
dherman201
I removed my gas oven when doing some remodeling an unfortunatly bent the rigid aluminum tubing that connect from the flex gas line to the back of the over. I think it is actualy part number AP2026980 . It have flare fittings on both ends but on my oven it is bend like a horseshoe and the in the catalog it is straight. I know these are hard to bend without the proper tool. Do you think I have the right part?
#2 Posted : Friday, May 21, 2010 4:47:21 PM(UTC)
The new tube comes straight and has to be bend at the installation time. You have to use a special bending tools to do it right. The part number you posted is correct.
The bending tools:
- The set of bending springs Part number: AP3550535
or
- The bender Part number: AP3551097
