sca003
#1 Posted : Friday, May 21, 2010 4:06:19 PM(UTC)
sca003
It Seems That My Roper Washer Will Not Drain Out The Accumulated Water After The Initial Wash Cylcle And Will Not Finish The Drain Cycles, Any Ideas Why Or How To Fix That?
It Stops Working Just Before Rinse Cycle.
#2 Posted : Friday, May 21, 2010 6:03:41 PM(UTC)
Originally Posted by: sca003 Go to Quoted Post
...It Stops Working Just Before Rinse Cycle...
Does the motor run?
Remove the washer cabinet and the pump. Check the pump and its hoses for a foreign objects inside.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RAS6233KQ0 | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 21 time(s).
How to remove the pump.doc (25kb) downloaded 15 time(s).
