AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
flashing accusensor light, non functioning cancel button
I am having a problem with my dishwasher in that the cancel button is inoperable and I cannot run another washing cycle. The accusense buttonlight is flashing and the "time remaining" area is lighted with two horizontal dashes. When hitting the cancel button, the "normal" cycle light flashes but then it stops and the accusense light returns to flashing. Unplugging the unit for a hour or so made no difference. Also, this problem happened before and a technician installed a new electronic circuit board in it that seemed to work "for a while" until now. What could be causing this problem and is there a real solution to it other than buying another dishwasher? Or worse yet another circuit board? Obviously it wasnt a circuit board problem and hopefully I havent "toasted" this latest one because of some "hidden culprit". Thank you. Jay Hlavaty
Dishwasher Repair
