leakyparts
#1 Posted : Tuesday, May 11, 2010 11:12:52 AM(UTC)
leakyparts
My Kenmore Elite dishwasher usually leaks at the door during a dishwashing session (sometimes it doesn't leak, but it does leak more often than not).
I've try to notice if how I load the dishwasher makes a different but can't see any difference.
We've checked to make sure the dishwasher was level (it was ever so slightly off and we made the right adjustments)--but it still leaked.
We changed the door seal/gasket--it still leaks.
What else can be causing our leak? What else should we try?
#2 Posted : Tuesday, May 11, 2010 2:22:32 PM(UTC)
Have you determined where it's leaking from?
At the time when it's leaking, open the door and check for suds inside.
Kenmore DW leaking after new door seal (Dishwasher Repair)
by ucmba97 10/18/2009 9:31:25 AM(UTC)
