ucmba97
#1 Posted : Sunday, October 18, 2009 9:31:25 AM(UTC)
ucmba97
had water on kitchen floor after overnight wash cycle. Replaced large door seal and small lower seal. Ran test wash, still dripping from lower section of door, albeit a little less than before.
Water level seems high. How high should it be when I open the door mid cycle?
After cycle completes, there is still water in the tub bottom.
Float and float switch tested good.
Drain under sink unhooked, and tested for backflow. Valve seems good as no water flowed back into the dishwasher when the hose was filled from the sink end and raised above the DW.
no soap has bene use din last 2 test cycles, yet water is very sudsy.
I'm not sure what to do next....and suggestions?
ucmba97
#2 Posted : Sunday, October 18, 2009 10:21:06 AM(UTC)
ucmba97
UPDATE: could it be as simple as the rinse aid cup was overfilled??
I filled it last wednesday.
Just emptied it, and am running a test cycle...no leaks so far.
Why is it suds can leak out but water without suds doesn't leak out?
