mesulfyus
#1 Posted : Monday, May 10, 2010 10:41:06 PM(UTC)
mesulfyus
The refrig at first when we plugged in didnt turn on except the light. door got slammed,:mad:, and started working great. ran for a few days then seemed to quit working again except for the light. temp was at 60 degrees in compartment. adjusted the temp setting to high was running near 7 but went to 9 to see if it would kick on but nothing. then turned dial to off heard click then turned back on to 8.5. refrig eventually cut back on "no slamming involved,:)" but never got below 50 degrees and kept running.
magician59
#2 Posted : Tuesday, May 11, 2010 6:29:05 AM(UTC)
magician59
Check the freezer for signs of defrost failure, i.e. snowy ice build-up on and behind the freezer wall. Be aware, though, that given the age of the appliance, you may also have a leak in the sealed system, causing low, or no freon.
mesulfyus
#3 Posted : Tuesday, May 11, 2010 10:06:01 AM(UTC)
mesulfyus
will the freezer still work properlly if the whole unit is low on freon or has a freon leak.
mesulfyus
#4 Posted : Tuesday, May 11, 2010 10:07:11 AM(UTC)
mesulfyus
can the freezer still work correctly if unit is low on freon or leaking?
mesulfyus
#5 Posted : Tuesday, May 11, 2010 10:08:51 AM(UTC)
mesulfyus
it seems the air flow to the fridge is not working properlly, but works fine in freezer. is there a manual available so that i can properlly dismantle the unit?
