My maytag washer appears to have a leak underneath. We notice water coming from under and when we move the machine the puddle is about in the middle. Is there an easy way to watch this while using to determine exact cause?
at bottom of front panel there are 2 screws . remve them ,then pull forward and up and off. put panel to side .turn on machine +observe with light, all around, especially around centre under transmission+to left between outer tub +lid at back top
Thanks for your help. I now have the front cover off and hopefully it will leak when I am watching it. Thanks Again!
