smcneil
#1 Posted : Saturday, May 10, 2008 11:37:29 AM(UTC)
smcneil
My maytag washer appears to have a leak underneath. We notice water coming from under and when we move the machine the puddle is about in the middle. Is there an easy way to watch this while using to determine exact cause?
misterfixall
#2 Posted : Saturday, May 10, 2008 12:01:38 PM(UTC)
misterfixall
at bottom of front panel there are 2 screws . remve them ,then pull forward and up and off. put panel to side .turn on machine +observe with light, all around, especially around centre under transmission+to left between outer tub +lid at back top
smcneil
#3 Posted : Monday, May 12, 2008 11:04:46 AM(UTC)
smcneil
Thanks for your help. I now have the front cover off and hopefully it will leak when I am watching it. Thanks Again!
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Maytag Washer leaks (Washer Repair)
by A00446849 2/20/2012 9:31:31 AM(UTC)
Maytag Washer leaks on side of drain hose (Washer Repair)
by della 12/17/2011 10:34:04 PM(UTC)
maytag washer leaks (Washer Repair)
by kramler92 12/7/2011 4:47:43 PM(UTC)
Maytag Washer leaks at bottom (Washer Repair)
by ronf 10/23/2010 6:07:28 AM(UTC)
Maytag washer leaks on the bottoom (Washer Repair)
by Bummer plumber 9/9/2010 7:56:24 AM(UTC)
Maytag Washer Leaks (Washer Repair)
by badodd 8/5/2010 5:15:33 PM(UTC)
by fabian g 7/1/2010 4:53:31 PM(UTC)
Maytag washer leaks as soon as its filling (Washer Repair)
by TonyCud01 4/3/2010 8:21:11 AM(UTC)
Maytag Washer Leaks at Drain Cycle (Washer Repair)
by ganzhimself 12/13/2009 6:52:55 PM(UTC)
by mriley44 12/9/2008 2:02:03 PM(UTC)
My Maytag washer leaks onto floor (Washer Repair)
by mbrew5335 12/26/2007 12:21:13 PM(UTC)
