andreagoldwing
#1 Posted : Thursday, May 6, 2010 6:01:42 AM(UTC)
andreagoldwing
Hello,
I have a problem with my dishwasher machine. It is a Whirlpool GU1108XTLB0.
The problem is that it works only the china crystal program. All other
programs do not work if I press the buttons and even the buttons lights
do not come on. Moreover, when I use the china crystal program, sometimes
it stop working before the program ends and the cancel and the program
lightes blinks. Sometimes it finish the program but after a while it
stars the program again.
Any clue?
#2 Posted : Thursday, May 6, 2010 11:44:18 AM(UTC)
Most likely the problem is a bad keypad assembly which is a part of the console, but there is a small chance for the control board to be bad as well. I would replace the console first. If you need the correct part number for the console, post the color of it.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU1108XTLB0 Undercounter Dishwasher | AppliancePartsPros.com
#3 Posted : Thursday, May 6, 2010 1:35:35 PM(UTC)
You could improve your odds of getting the correct part by checking the keypad/console with a meter. If it checks out OK then it is more likely to be the control board that is the problem.
Here is the tech sheet with info on checking the keypad
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208537797.pdf
You could also try the following though it is a long shot as sounds like you have a large number of keys that are not working.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
