Had to disconnect/unplug and move washer last night, reconnected it plugged it in and forgot to turn on the hot water supply valve. Wife ran washer last night and now the door is locked and stuck on rinse cycle. Water is turned on and hose is full of water(no airplug in hose). Have unplugged and plugged back in and pressed all buttons(Pause,Cancel,Start,etc.) Door is still locked and same constant noise coming from washer. Do not have manual. Any suggestions to just get the door open to get laundry out would be helpful. Any suggestions on how to get it to start over on a brand new cycle would be even more helpful.
To manually unlock the door you have:
1. Unplug the power cord 2. Remove the bottom panel 3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly 4. Located on the bottom of the door latch assembly is a tear-drop shaped tab 5. Gently pull the tab down about 1/4" or until a click is heard
The door may now be opened.
