ev372
#1 Posted : Monday, May 3, 2010 11:26:43 AM(UTC)
ev372
My Kenmore Elite Oasis HE washer is making a grinding sound during the spin cycle, under the tub. Water is being pumped out and the basket/tub is spinning. It is direct drive and I wonder if a bearing or motor issue is the problem? Anybody have diagrams/directions on how to remove the motor and stator unit, and any ideas on what might be the problem? Any help would be great; Gene are you available? Thanks everybody.
scouterlen
#2 Posted : Thursday, May 27, 2010 7:38:19 PM(UTC)
scouterlen
I have the same model number and what sounds like the same problem. I took the back off and felt the pumps while it was making the noise. The discharge pump was vibrating badly while it was in use. I took the pump off the tub and ran it while it was dry and it almost jumped out of my hand. I am going to try a replacement pump and will post the result
