LastEagle181
#1 Posted : Friday, April 30, 2010 2:07:55 PM(UTC)
LastEagle181
My washer will fill up with water,pump it out,but never agitate or spin. You can spin the drum by hand & spin the belt by hand freely. I replaced the lid switch already because while all this was happening it didn't shut off when you lift the lid. That made no difference either. Still makes humming noise lid open or closed. What could it be?
sidfink43
#2 Posted : Monday, May 3, 2010 6:06:09 AM(UTC)
sidfink43
Your machine has an inverter built into the motor. This gives error codes by flashing lights. This site will show you how to interpret the lights.
HydroWave GE Washer Repair Guide
Before you do any repairs, check the fuse and try resetting the machine using the instructions on that site. A lot of times one of these actions will fix things.
LastEagle181
#3 Posted : Monday, May 3, 2010 7:25:52 AM(UTC)
LastEagle181
I really appreciate all the help. I stumbled on this site quite by accident & everbody seemed very informative so I tried it out. Well guess what world??? IT WORKS!!! Great information & super reliable help. I'm sorry to say I found my cure browsing your site before you got back to me but that's okay...it's the same one you emailed me. This is a fantastic site for us home owners who cannot afford a repair man all the time.
Keep up the good work,,if nobody else has said it Sid, we appreciate you!:)
myphan29
#4 Posted : Monday, May 3, 2010 7:45:57 AM(UTC)
myphan29
my wahing machine won't wash it only spin and drain the water out I need technical support to help with this
sidfink43
#5 Posted : Monday, May 3, 2010 9:26:10 AM(UTC)
sidfink43
Myphan
Please start a new thread and list your brand and model number and someone may be able to help you.
Guest (4)
