tomted1
#1 Posted : Thursday, May 8, 2008 10:01:03 AM(UTC)
tomted1
The gas dryer is electrically energized and hums, although the drum doesn't turn, when the door is closed or open. The only method of turning it off is to either set the timer to zero or unplug it. The drum doesn't turn when the door is closed and the timer has minutes on it. Pushing the start button makes no difference.
misterfixall
#2 Posted : Thursday, May 8, 2008 11:14:01 AM(UTC)
misterfixall
check to see if drum belt is broken. possible motor problem if belt not broken
SublimeMasterJW
#3 Posted : Thursday, May 8, 2008 12:02:00 PM(UTC)
SublimeMasterJW
Look in and see if the belt is broken. From what you are describing it sounds like the gas assembly is trying to fire but the drum ain't turning. To replace the belt you are gonna have to remove the front panel. You may as well give it a good cleaning while you are at it. Also inspect the slides and rear bearing.
tomted1
#4 Posted : Thursday, May 8, 2008 12:58:52 PM(UTC)
tomted1
Thanks mfa and SMJW but why would the motor be energized when the door is closed?
SublimeMasterJW
#5 Posted : Thursday, May 8, 2008 2:03:59 PM(UTC)
SublimeMasterJW
when you shut the door the gas trys to work . must be getting power through that switch. I have seen it. Check the motor swtch. One that old might be all full of stuff and sticking. Did you break down the dryer yet? Get the drum out, clean and inspect the motor.
tomted1
#6 Posted : Thursday, May 8, 2008 9:59:19 PM(UTC)
tomted1
OK, back from work and able to flip front panel and see that the belt is in place. I guess I'll look to the motor. It is nearly 18 years old so that wouldn't be too surprising. Hmmm, if it's the motor, do I replace it or buy a new dryer? I've replaced the slides and rear bearing, some gas valve parts and been through a couple of igniters over the years.
SublimeMasterJW
#7 Posted : Friday, May 9, 2008 3:39:03 AM(UTC)
SublimeMasterJW
These newer appliances are not worthy to stand next to a fine old machine like that. The motor is really the heart of the dryer. I would definately replace it.
dryer malfunction (Dryer Repair)
by Mike Julian 5/24/2017 12:32:37 PM(UTC)
Dryer Malfunction (Dryer Repair)
by RenoRandy 1/16/2011 9:10:09 AM(UTC)
GE Dryer Malfunction - Timer or Thermostat? (Dryer Repair)
by Manfred 1/4/2011 7:04:30 AM(UTC)
