smcneil
#1 Posted : Tuesday, May 6, 2008 10:08:05 AM(UTC)
smcneil
What is the easiest way to replace the front drum glides?
SublimeMasterJW
#2 Posted : Tuesday, May 6, 2008 10:49:50 AM(UTC)
SublimeMasterJW
You could rebuild the old slides or you can buy a pair of new ones.
Open the door to the dryer.
Remove the 4 screws that hold down the top(torx drive)
raise the top and remove the front panel.
your glides are right there easily accessable
at the base of the drum.
Easy repair.
SublimeMasterJW
#3 Posted : Tuesday, May 6, 2008 10:55:15 AM(UTC)
SublimeMasterJW
UserPostedImageIf you are don't want to spend 30 bucks on a set of these puppys you can always buy the el cheapo repair kit
It comes with 2 rivits a backer pad and a slide.
smcneil
#4 Posted : Thursday, May 8, 2008 11:33:22 AM(UTC)
smcneil
Followed you instructions and was very easy. Thanks for your help.
SublimeMasterJW
#5 Posted : Thursday, May 8, 2008 11:46:47 AM(UTC)
SublimeMasterJW
Glad to help. It makes me happy to do so. Someone long ago took the time to show me.
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
