gomabus
#1 Posted : Tuesday, April 1, 2008 7:00:03 AM(UTC)
gomabus
My window unit was not cooling nor heating. I replace the thermostat. It is cooling now but not heating. I was told to replace the fuse link or swith limit. I can not locat either on the unit. Where are they located?
kooler
#2 Posted : Thursday, April 10, 2008 4:23:04 PM(UTC)
kooler
Click on your model and APPros has pictures of your model that show the limit switch location... Use a multi-meter to check continuity of the limit switch and heating element before replacing... Check all wiring and connections too..
SublimeMasterJW
#3 Posted : Tuesday, May 6, 2008 4:34:57 PM(UTC)
SublimeMasterJW
Part number 45 on the parts list at APP
UserPostedImagethe part is mounted on the heater insert.
It slides out of the unit and fits right in front of the evaporator in a bit of a tight spot.
Product Code location (Refrigerator & Freezer Repair)
by turtlejay 2/3/2024 12:09:21 PM(UTC)
Gearcase Washer # W11032711 (AP6038816) Location (Washer Repair)
by Unklr 12/30/2023 3:08:55 AM(UTC)
Washer filter location (Washer Repair)
by Guest 8/27/2022 11:31:23 AM(UTC)
Inverter PBC Location on Samsung RSG257/AARS Fridge (Refrigerator & Freezer Repair)
by nwiles1414 1/18/2022 6:53:36 AM(UTC)
New Gas connections new location.. NO NOTHIN! (Oven Repair (including Ranges and Cooktops))
by 651learnatrade 10/18/2020 10:32:17 PM(UTC)
Samsung FL Washer Replacement rear half tub does not work with existing drain pump location (Washer Repair)
by motoman3 1/14/2020 8:12:15 PM(UTC)
Samsung RSG257AARS Inverter Location (Refrigerator & Freezer Repair)
by pcl1194 7/30/2019 8:30:29 AM(UTC)
Looking for location on control board where user interface connects (Washer Repair)
by waddatoe 4/13/2019 1:00:57 PM(UTC)
GE Side by Side Thermistor Locations (Refrigerator & Freezer Repair)
by AlkiRich 1/3/2019 9:31:00 PM(UTC)
Control timer location (Refrigerator & Freezer Repair)
by Dang1956 6/23/2018 6:33:59 AM(UTC)
KitchenAid Range power board location (Oven Repair (including Ranges and Cooktops))
by Wkar17 11/9/2017 12:26:50 PM(UTC)
Diode location (Microwave Repair)
by Creede 1/18/2017 4:12:39 PM(UTC)
Reassembly Problem-ambiguous connector location (Oven Repair (including Ranges and Cooktops))
by Terry Ost 12/19/2015 3:45:26 PM(UTC)
Whirlpool adp 6650 : Thermostat location (Dishwasher Repair)
by biliron 9/6/2015 5:03:57 AM(UTC)
GE Refrigerator drain plug location (Refrigerator & Freezer Repair)
by Andrea42165 8/29/2015 8:17:16 PM(UTC)
