I have replaced a burner and am reassembling the cooktop. There is a black 4 pin connector that attaches to one of the control boards on the cover. On that control panel there are 2 identical board locations next to each other. Are these 2 board pin locations in parallel? Only one connector attaches for use. If they are not in parallel, which one is the correct set of 4 pins to connect to? This is the left control board (of 3). Is the correct set the one towards the center of the unit or to the left side of the unit? Appreciate any help. Thanks.
Perhaps the attachments will help. |
THIS FORUM IS DEAD!!!!!!! |
Thanks. The EW36 Hook Ups answered my question, they are in parallel. While the possibility of the 2 connection points being in parallel was highly probable, I didn't want to take the chance. You never know whether the designer was logical or not. Thanks for the quick response.
