yan
#1 Posted : Wednesday, April 23, 2008 10:11:05 AM(UTC)
yan
Hi, I have a Amana fridge that is only 3 years old.
The fridge and the freezer (bottom) is still working fine but I can hear a few times a day, a click-buzz-click sound.
When I get the sound, the compressor does not start. The buzz sound last for about 3-5 seconds. A few minutes after the sound, the compressor starts normally.
Is there anything I can do before it totally fail, is it already too late ? Thanks for your help.
Note: There is no Ice maker in that fridge.
misterfixall
#2 Posted : Wednesday, April 23, 2008 1:14:37 PM(UTC)
misterfixall
you may have a weak start relay on compressor
yan
#3 Posted : Wednesday, April 23, 2008 3:20:57 PM(UTC)
yan
From what I can see, the buzzing sound comes from the compressor itself. Do you think that a weak relay could make the compressor buzz ?
Is there a way to figure out (exept from replacing it) ?
misterfixall
#4 Posted : Wednesday, April 23, 2008 5:50:00 PM(UTC)
misterfixall
it will be easier for you just to replace relay than testing compressor seeing your not a tech
yan
#5 Posted : Tuesday, May 6, 2008 12:50:39 PM(UTC)
yan
I first tried to replace the relay but it was still doing the same thing.
As soon as the compressor whould become a bit too hot, it would not start anymore.
A called the technician and they replaced the compressor.
Thanks for you help.
