3 Pages<123>
n2wind2000
#11 Posted : Sunday, April 25, 2010 9:05:05 AM(UTC)
n2wind2000
OK, I have narrowed it down to a drain cycle. After the noise stops, I opened the dishwasher and the tub is emptied of water. It also occurs right when the machine has turned on, on any cycle. It last for just maybe 5 seconds, then begins to fill up. No issues other then when the machine is draining/emptying.
#12 Posted : Sunday, April 25, 2010 1:20:03 PM(UTC)
You may want to check the drain pump. Unfortunately I'm not able to give you more specific instructions without the model number.
n2wind2000
#13 Posted : Sunday, April 25, 2010 3:12:25 PM(UTC)
n2wind2000
Model # FD889450C1
All your help/assistance is greatly appreciated! If you have any auto detailing needs, let me know!
#14 Posted : Tuesday, April 27, 2010 11:15:26 PM(UTC)
The model number you posted does not look as a valid Frigidaire model number. Try to use the model number locator.
n2wind2000
#15 Posted : Wednesday, April 28, 2010 11:39:33 AM(UTC)
n2wind2000
Well thats rather interesting. I took the number off the frame abutting the door. Model # was listed right below Serial #. Does Electrolux ring a bell? As the dishwasher wears a Frigidaire badge, but names Electrolux on the Model/Serial tag.
#16 Posted : Wednesday, April 28, 2010 12:55:33 PM(UTC)
Frigidaire belongs to Electrolux. Electrolux bought it a few years ago.
Model number is always on top of serial number. It should start with three or four letters.
n2wind2000
#17 Posted : Wednesday, April 28, 2010 8:08:43 PM(UTC)
n2wind2000
Gene, its either an F or an E, then DBB945DC1. Hope THAT helps, cuz Im SOL if thats not it....
#18 Posted : Friday, April 30, 2010 2:35:33 PM(UTC)
It's an F!
The drain pump is located on the right side of the main pump sump (#60 on the diagram). You probably have to remove the dishwasher from the cabinet to access it.
Remove the drain pump and check the pump and its hoses.
- The drain pump Part number: AP4319432
Zeb60
#19 Posted : Wednesday, January 7, 2015 12:38:47 PM(UTC)
Zeb60
Originally Posted by: kevamhenry Go to Quoted Post
I have a similar bosch with model number shx46bo7. This past week came in from outside to find dishwasher making loud noise from the underneath. When I turned off the water shut off valve the noise quit. Have tried running a few loads since. The machine starts and seems to run fine. It intermitantly makes this grinding/fluttering noise. If I slowly turn the water shut off valve off slowly the noise quits. I am able to immediately slowly reopen the valve without noise returning until later in the cycle. I reapeat this step over and over. I have searched many forums and your answer is the only one close to my problem. Is this a problem with my water valve or is a part on my machine probably starting to break and needs replaced? I have fixed my kenmore washer and dryer issues so hoping I can fix this too.
I'm having this exact same problem. Noise starts, shut the water valve, noise stops then runs fine. Does it towards the end of the cycle. Any suggestions? Bosch model #SHE44C06UC
Zeb60
#20 Posted : Wednesday, January 7, 2015 12:39:41 PM(UTC)
Zeb60
I'm having this exact same problem. Noise starts, shut the water valve, noise stops then runs fine. Does it towards the end of the regular wash cycle but not on the quick wash cycle. Any suggestions? Bosch Dishwasher model #SHE44C06UC
Guest (4)
3 Pages<123>
