smith972
#1 Posted : Saturday, May 3, 2008 4:25:33 PM(UTC)
smith972
The washing machine is leaking from under the tub between the transmission and the tub but I cant seam to figure out how to remove the tub.
I have the agatitor (sp) out the bolts at the bottom of the inside tub out, the top of the tub off but i still have the outter tub and the inner tub that are still attached.
Can I get to the seals just by removing the inner tub and leave the outter tub still attached w/o having to remove the nuts holding that in place? If so how do i remove the inner tub?
I really need to get this machine working as we have been w/o a washing machine for a week now. I have done as much research as possible on the internet for this model and I dont have a manual for this model.
Attached you will find a picture of the inside of the tub and the bottom of the tub where the leak is coming from. If you need addtional pictures please let me know and I will try to get a better picture using my dig. cam.
This single mother of 5 thanks you in advance.
smith972 attached the following image(s):
ApplianceJunk
#2 Posted : Saturday, May 3, 2008 6:41:14 PM(UTC)
ApplianceJunk
See if this info help.
http://www.servicematters.com/m...rary/docs/TDL-0086-B.pdf
I could not find the service manual off hand, but I should have it someplace.
If you need the manual send me a email and I will dig it up for you.
AJ
smith972
#3 Posted : Sunday, May 4, 2008 5:51:22 AM(UTC)
smith972
This may sound stupid but where do i buy the kit described in the information....also the tools where do i buy those????
thanks
smith972
#4 Posted : Sunday, May 4, 2008 6:06:10 AM(UTC)
smith972
I found the parts but my question is this parts and tools together will cost 176.45 is this machine worth fixing?
Jada
How to remove the tub from GE stackable washer dryer combo (Washer Repair)
by MSJORDAN 6/2/2015 11:42:26 AM(UTC)
