The washing machine is leaking from under the tub between the transmission and the tub but I cant seam to figure out how to remove the tub. I have the agatitor (sp) out the bolts at the bottom of the inside tub out, the top of the tub off but i still have the outter tub and the inner tub that are still attached. Can I get to the seals just by removing the inner tub and leave the outter tub still attached w/o having to remove the nuts holding that in place? If so how do i remove the inner tub? I really need to get this machine working as we have been w/o a washing machine for a week now. I have done as much research as possible on the internet for this model and I dont have a manual for this model. Attached you will find a picture of the inside of the tub and the bottom of the tub where the leak is coming from. If you need addtional pictures please let me know and I will try to get a better picture using my dig. cam. This single mother of 5 thanks you in advance. smith972 attached the following image(s):
This may sound stupid but where do i buy the kit described in the information....also the tools where do i buy those????
thanks
I found the parts but my question is this parts and tools together will cost 176.45 is this machine worth fixing?
Jada
