3 Pages123>
c2heinen
#1 Posted : Saturday, May 3, 2008 11:46:39 PM(UTC)
c2heinen
I was wondering what could be wrong with my dryer. The tub quit turning this evening. And would it be worth repairing? Price wise?
c2heinen
ApplianceJunk
#2 Posted : Sunday, May 4, 2008 5:42:46 AM(UTC)
ApplianceJunk
If you can still hear the motor running, but the drum just does not turn on it's own anymore then you need a new belt.
Drea_93
#3 Posted : Wednesday, May 7, 2008 9:16:44 AM(UTC)
Drea_93
How would I change the belt on Whirlpool Estate Dryer (EED4300TQ)? I have removed the back, but could not find anything back there. Is there some type of manual I can get to do this?
SublimeMasterJW
#4 Posted : Wednesday, May 7, 2008 1:59:12 PM(UTC)
SublimeMasterJW
yank the filter out the top
remove the 2 screws holding the filter housing to the top.
pop the top using putty knife.
remove crews from inside front panel.
Raise up on front panel and remove.
remove the drum and inspect the idler and wheels
replace all defective parts. make sure the belt is not twisted.
Insert the idler into the floor and raise it up so that you can loop the belt onto the motor pulley. replace the front and snap down the top. Easy fix.
booper
#5 Posted : Sunday, July 13, 2008 6:37:35 PM(UTC)
booper
how did you repair? the same as the whirlpool??
booper
#6 Posted : Sunday, July 13, 2008 6:38:25 PM(UTC)
booper
I too have an estate, did the directions to the whirlpool work for you?
thank you
booper
#7 Posted : Sunday, July 13, 2008 6:42:36 PM(UTC)
booper
sorry to be a pest, is there a manual (online) somewhere?
thank you
ApplianceJunk
#8 Posted : Sunday, July 13, 2008 7:14:05 PM(UTC)
ApplianceJunk
Not sure what you model number is but you maybe able to find your service manual here.
http://appliancejunk.com...dex.php?action=downloads
booper
#9 Posted : Sunday, July 13, 2008 7:36:17 PM(UTC)
booper
thank you the dryer is an estate TGDS840JQ1
i hope tht I can repair this...is this too hard for a female with some mechanical (though very limited) abilities?
SublimeMasterJW
#10 Posted : Monday, July 14, 2008 5:46:44 AM(UTC)
SublimeMasterJW
An estate is a plain jane whirlpool dryer without all the fancy bells and whistles. My directions above will work:yank the filter out the top
remove screws from inside front panel.
Guest (5)
3 Pages123>
