Hi all, check here often for info thanks alot. Whirlpool oven, had error code e1 f2 , replaced board now still have the same code, went off for about 60 sec when first installed now still on. Keypad , or what ya think ? Connections are all good. TIA Jeff
There Is A Test For Board Or Keypad. Seeing You Already Relaced Clock ,which Seems Not Have Been The Problem. Replace Keypad
