pgilliam1
#1 Posted : 15 years ago
pgilliam1
I bought this unit used (unit was never installed), got it home, wired it up and got these error codes. The first code (E0 F2) tells you to replace the keypad. The code now (E1 F2) suggests to replace the board. Does anyone know the part numbers (I don't know what parts the "keypad" and "board" refers to) and price of these items?
Sincerely and Thankfully,
Pat
#2 Posted : 15 years ago
Hi Pat,
Open the control panel. Remove the keypad ribbon cable from the control board. Clean the edge connector with a pencil eraser. Check the tracks in the ribbon cable for a hairline tracks using a magnifying glass.
Clean the connector on the board using electronics contact cleaner or isopropyl alcohol and a tooth brush. Be careful not to damage it. Let them dry. Reconnect everything and give it a try.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GBS307PRB01 30" Built - in Electric Oven Self Clean Convection (gold Line) | AppliancePartsPros.com
pgilliam1
#3 Posted : 15 years ago
pgilliam1
Hi Pat,
Gene,
I had already done this on both connectors (keypad and board) and checked continuity on all the leads through the ribbon cable - all are OK. I was hoping someone could lead me to either the touch keypad or the main board for replacement. I don't know which one to try first and they're both fairly exspensive.
My Sincerest Thanks for your time and advice,
Pat
#4 Posted : 15 years ago
Pat,
According to the tech sheet the first try should be the membrane switch (keypad). If you need the correct part number, post the color of it.
pgilliam1
#5 Posted : 15 years ago
pgilliam1
Pat,
Gene, you're a very helpful guy/gal and I want you to know I appreciate all your help. I ordered the keypad and am crossing my fingers.
My Sincerest Thanks,
Pat
#6 Posted : 15 years ago
You are welcome Pat.
Hopefully it will fix the problem. Good luck and keep us posted.
pgilliam1
#7 Posted : 15 years ago
pgilliam1
Bingo, right on the money! The keypad fixed the problem and my wife is cooking brownies - Woo-Hoo!
Thanks Again Gene!
#8 Posted : 15 years ago
You are welcome. I'm glad you were able to fix it.
