grumpy54
#1 Posted : Sunday, March 30, 2008 5:41:15 PM(UTC)
grumpy54
Problem with FINAL spin cycle,,,,, it works on one of the settings,(heavy duty) but will not do final spin on 2 of the other settings. Do I need to replace the timer, or something else?
#2 Posted : Monday, March 31, 2008 1:29:35 PM(UTC)
Most likely the problem is a bad timer.
- The part number for the timer is AP3099903
Here are the break down diagrams for the Whirlpool washer Model LA8580XWW2
sailman
#3 Posted : Saturday, May 3, 2008 7:54:23 AM(UTC)
sailman
I had same problem. thought it was timer. saw another post with same prob. he ran cycle with no clothes, just water and it would spin in cycle that would not spin with clothes in. I did same experiment and had the same outcome; it went through the full cycle without clothes in Regular. So it was not the timer at all. Check the clutch slipping, lid switch or water level switch. I am a weekend pro.
Kenmore Washer spin problem (Washer Repair)
by vlherring 1/17/2023 8:10:33 AM(UTC)
Spin problem... (Washer Repair)
by sandesmith 1/22/2018 4:59:14 PM(UTC)
whirlpool washer spin problem (Washer Repair)
by roadranger82 6/17/2017 11:13:55 AM(UTC)
Kenmore washer 80 series spin problem (Washer Repair)
by Ikisntel 5/18/2015 10:50:24 AM(UTC)
by Ikisntel 5/17/2015 11:49:40 PM(UTC)
spin problems (Washer Repair)
by dph 4/14/2015 5:58:03 AM(UTC)
Kenmore 90 series washer spin problem (Washer Repair)
by NikoletteFancy 3/26/2015 5:51:18 AM(UTC)
Spin problems (Washer Repair)
by buckman 10/6/2014 12:35:59 PM(UTC)
Amana spin problem-topload (Washer Repair)
by gordonbegone 8/25/2014 2:27:05 PM(UTC)
LG WM1814CW spin problem (Washer Repair)
by rod910 3/17/2014 3:57:40 PM(UTC)
Kenmore 90 Series spin problem, loud noise (Washer Repair)
by dy95 3/15/2014 2:56:47 PM(UTC)
Spin problem with Whirlpool washer (Washer Repair)
by trailrider1 10/13/2013 6:57:24 AM(UTC)
Tumble/Spin Problems following Broken GE Front Loader Washer (Washer Repair)
by jimhenkle 9/27/2013 7:50:43 AM(UTC)
Maytag bearing replaced, spin problem (Washer Repair)
by nobull1466 4/9/2013 3:12:59 AM(UTC)
Help me with spin problem (again) (Washer Repair)
by twentw 3/21/2013 3:16:08 PM(UTC)
