:confused: I replaced the water inlet valve and my washer still dribbles in the tub by the time I get home i have a full tub of water. Defective part or maybe its the water level pressure switch?
Does the same thing happen when you leave the machine unplugged?
no only when it is plugged
At first it looked like the water was still dripping but now that the power has been shut off to it for some time i can tell that it is not, so it only leaks when it is plugged in
Then it sounds like you have a bad valve. They get fouled up with deposits from the water, and won't close all the way. If you just clean the screns at the valve inlet, there's a chance for damage to the screen(s), making a bigger hole and allowing more sediments into the valve.
Originally Posted by: magician59  Then it sounds like you have a bad valve. They get fouled up with deposits from the water, and won't close all the way. If you just clean the screns at the valve inlet, there's a chance for damage to the screen(s), making a bigger hole and allowing more sediments into the valve. :) thx for all your help an sorry it took so long to reply ive been off line for some time. i replaced the valve an still had a problem but it turned out to be a defective part so now all is well thx again
