FreezeTag
#1 Posted : Wednesday, April 21, 2010 9:02:33 AM(UTC)
FreezeTag
:confused: I replaced the water inlet valve and my washer still dribbles in the tub by the time I get home i have a full tub of water. Defective part or maybe its the water level pressure switch?
magician59
#2 Posted : Wednesday, April 21, 2010 10:22:12 AM(UTC)
magician59
Does the same thing happen when you leave the machine unplugged?
FreezeTag
#3 Posted : Wednesday, April 21, 2010 1:56:51 PM(UTC)
FreezeTag
no only when it is plugged
FreezeTag
#4 Posted : Wednesday, April 21, 2010 4:27:00 PM(UTC)
FreezeTag
At first it looked like the water was still dripping but now that the power has been shut off to it for some time i can tell that it is not, so it only leaks when it is plugged in
magician59
#5 Posted : Thursday, April 22, 2010 7:53:39 AM(UTC)
magician59
Then it sounds like you have a bad valve. They get fouled up with deposits from the water, and won't close all the way. If you just clean the screns at the valve inlet, there's a chance for damage to the screen(s), making a bigger hole and allowing more sediments into the valve.
FreezeTag
#6 Posted : Monday, May 17, 2010 8:40:30 AM(UTC)
FreezeTag
:) thx for all your help an sorry it took so long to reply ive been off line for some time. i replaced the valve an still had a problem but it turned out to be a defective part so now all is well thx again
