I wanted to post an update: I just replaced the rotary start switch on my GE dryer and it fixed the problem I was having. The repair was quick - probably 5 minutes total to remove the back top cover, label and remove the two red and two gray wires from the old switch and replace the switch, wires and cover. Just tested it and the start switch is back in action! Thanks for all your help!
Well done! And thank you for the update.
